Motor mount issues
do you have the mount installed upside down?
I was thinking that too, but the way the angle is I think it can only fit on the block one way
Here is the GM parts breakdown for the mount. I've had no luck searching for a direct replacement. May have to go over to your local GM parts counter to see if it has been superseded with a new number and if not available, see if the non GM parts counter can check for a direct replacement this way.
are you trying to line up the side in your first photo with the other side in place with the bolt keeping it in place?
