Motor mount issues
Froggys86
231
55
California
I am in need of some help I recently bought motor mounts for my 86 Cutlass and the bottom bolt does not line up to frame so I can slide bolt in. It seems like it's sideways, I thought about making other holes for bolt but inner by starter doesn't have enough room for me to do so.....has anyone had this issue before......they're from O'Reilly's part #A2328 and if so how can I fix the problem. Thanks in advance. And has a v8 307 motor in it.
Bri guy
845
225
I bought the same ones from there. I didnt want to deal with the head ache so i paid the shop around 100 to Put them in. They only lasted a few months. Ended up buying some stronger ones from supercar unlimited to replace the orrielley ones
Froggys86
231
55
California
Did they line up tho
Bri guy
845
225
Everything went fine. I didnt hear any complaints. Took less time than they thought. Maybe you bought a defected one?
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
I had that issue when I tried to put later mounts in my 70S, about the same amount from lining up. Pre 73 BBO and SBO used different mounts, all 73 to 90 RWD mounts are the same BBO or SBO. Sometimes some shifting and pushing with a pry bar is necessary to line them up. Loosen slightly where they attach to the block, might allow the necessary movement.
Reactions: 5 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Did you match them to the old ones?
Are they the same?
The box might have the correct part number but the part may be the wrong one.
Right box wrong part......it happens
Froggys86
231
55
California
Are they the same?
Kind of hard since torn but the part that sits on frame bravket is more of a curve and new one a lil more square...and maybe wrong part but both boxes since I bought 2
