Rockstar said:Unforunatly i dont. A good thing with not having the front wheel wells is you can mount the hinge to the core support close the hood and mark your holes through the wheel well. Make sure you unbolt the hood from the factory hinge before you mount the new hinge (dont ask how i know) How are you locking the trunk down so it cant be pulled up from the back (near the rear window)? Cause on mine with it closed you could still pull up on the hood (near the winshield).
well its pouring here to so i didnt feel like going out to take a picture of them, so i drew this on paint to show you. I will do something similar up front for the hood, but will either notch where they will hit or weld something in for them to "hook" into. I left the factory trunk mounts in the back about 2" so these arms will go in between the metal like it's a slot.
