richp85elco said:[youtube]TGu5TrxkVs8[/youtube]
Got her starting up good now!New battery helped but was still actin funny, I reused my old pcv valve from the 305 and it was in rough shape but still rattled when I shook it so I thought it was good. Turns out, it wasn't as soon as I replaced it, it now starts right up. 8) Still needs a good tune but starting it up was more of a concern. Timing is 36 all in at about 2600 and base is 14. From idle in park to idle in drive its going from 1000rpms to a little over 500rpms and begins running a little rough and stumbling. Is that big of a drop normal or how would I go about adjusting it on a 600cfm Holley? I would like it a little higher when in drive...
I Made good progress but while driving the trans felt like it did not want to shift and I had no kind of acceleration the engine revved up but i had to over rev to get it to move. This was a fresh rebuild but it sat for about a year. transmission fluid was full and TV cable was hooked up. Im using the stock bracket with the geometry corrector, im thinking that might something to do with it but I know its set right at max throttle the tv cable is all the way out as well. Would the Holley bracket help?
That rpm drop is a bit high. For carb a turn is go to your idle mixture screws and count how many turns it takes to lightly seat them. Remember that number incase you have to go back to that setting start at 1.25 turns out and keep going in or out half turns until you get the most vacuum. When you get close go 1/4 turns. Then when you get it to most vacuum go another 1/4 turn out. Where is your vacuum advance hooked to? I typically dont run vacuum advance but if I do it is usually manifold vacuum bottom of carb. Check it with vacuum off then hook it up turn idle down. About the rpm drop what cam are you running exactly and what stall did you put in. Sounds like you converter could be a little to tight.
80ELCAMINOFLAKE said::shock: :shock: wow ur doing the dayum thing...sweet!!
richp85elco said:80ELCAMINOFLAKE said::shock: :shock: wow ur doing the dayum thing...sweet!!
Thanks man..they had one more 2 more sets at the primo lot at pick your part in wilmington if your interested the way im doing it just bolts right in, its the cheapest upgrade
