my blazer brake upgrade / hub conversion plans
6spdg37s
369
259
did alota research on this and also my buddy is a huge s10 blazer guy
He is giving me belltech 2102 2" drop spindles
SKF wheel hubs - BR930497
AC Delco Calipers 18R1372 and 18R1373 (loaded calipers)
generic 04 blazer rotors of your choice
supposidly u can use the G body hoses or centric 150.66117 and 150.66118 hoses
ill let you know the end results when its done !
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,696
Spring, Texas
I think I read the drop spindles will widen the track (distance between front wheels) a little.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,696
Spring, Texas
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,176
9,779
Gainesville, Fl
The G-body brake hoses are the same length as the Blazer hoses, only if you decide to use the Blazer hoses, it requires an adapter due to the Blazer fittings using a different thread.. G-body hoses, no adapter needed. Very straight forward swap.
6spdg37s
369
259
hmm good catch guess I will get new G Body hoses
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,696
Spring, Texas
Longroof79
Oct 14, 2008
12,176
9,779
Gainesville, Fl
81msw79
391
124
roselle park , nj
You will also need to do some trimming on the upper a-arms. Go on belltech's site and follow the directions with pictures. You will break the upper arm mounting bolts if this step is skipped. And they also widden the track 3/8" - 1/2" which does not sound like alot but will put tires closer to the fender lips
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
This^^^
Put it lock to lock, and check clearance on the calipers and bolts.
Also, I recommend the Moog 5662 springs with the drop spindles.
