So you reclaimed it so you can sell it again, right. 😉Oh yeah, the cap that was on this truck when I got it somehow wound up at the junkyard. I sold it to a guy on marketplace. Guess he didn't want it anymore.
Now here is something my brother told me. Use the passenger side cushion on the driver’s side. They always have less wear.
Was thinking just the cushion itself. But completely know what you mean!True, but often there are seat belt holes or arm rest holes waiting to screw you out of that option. Or electric seat controls on the outboard side.
Not gonna lie, I thought about it for a minute.So you reclaimed it so you can sell it again, right. 😉
Yeah unfortunately the seats aren't symmetrical. I was hoping I could swap the cushions but the outside is more rounded than the inside.Now here is something my brother told me. Use the passenger side cushion on the driver’s side. They always have less wear.
Couple pieces of Velcro on a few hidden edges? Though with the heat that wouldn’t work even.Got my wiring harness from BD Diesel today. A bit overpriced for what it was, but it was convenient. Install was easy and I think I kept the wiring neat considering how many wires are involved. I hooked it up to the same scotchloks that were already on the wires from when this was installed before. I hate scotchloks but I didn't put them there so I don't feel bad for reusing them. Reused another hole in the dash for the switch too.
View attachment 204100View attachment 204101
It works as advertised. Operation is a bit odd, it doesn't engage in overdrive, so at highway speed you have to turn overdrive off, then blip the throttle to activate it. It works that way by design, it's just strange to get used to.
I got a Dashmat to try to keep the sun off of that hen's tooth of a dashboard. I really don't want to use any of the double sided tape they supplied, I'm hoping it naturally conforms to the dash a bit more that it is now.
Couple hot days will probably help lay it out a bit more. Sort of how a newly upholstered seat tightens up a bit after some time in the sunGot my wiring harness from BD Diesel today. A bit overpriced for what it was, but it was convenient. Install was easy and I think I kept the wiring neat considering how many wires are involved. I hooked it up to the same scotchloks that were already on the wires from when this was installed before. I hate scotchloks but I didn't put them there so I don't feel bad for reusing them. Reused another hole in the dash for the switch too.
The little things that can make a bad day. Good to catch it ahead of time. 👍Today I finally tackled the Killer Dowel Pin. The killer dowel pin, the 12 valve's Achilles heel, is a dowel pin that aligns the timing case with the block. It has been known to rattle out of its bore and get jammed up in the timing gears and cause all kinds of damage. The fix is a metal tab that goes over it to prevent it from coming out. Lots of places make kits for tabbing the KDP, some people make their own, I bought a kit from Geno's Garage, they specialize in Dodge Cummins stuff. It came with the tab, a longer bolt, the crank seal, some loctite, and some black RTV.
The RTV looked suspicious so I used my own Permatex 5 minute gasket. Could've bought a gasket too but Cummins themselves switched to RTV on the later 5.9s so I don't feel guilty. Fortunately my dowel pin was still firmly seated in it's bore but the timing cover seal was leaking so that is fixed, and now I don't have to worry about the potential catastrophic failure if it were to fall out.
