Well I had to wave the white flag today. Before I take this pig in for inspection, I want to replace the passenger side ball joints. The drivers side feels pretty tight, but the passenger side had a little more play than I'm comfortable with and I'm positive it would fail inspection for it.
So I bought two new ball joints and began working on it in the driveway. About 10 mintues after I got the hub off, it began snowing. So I worked through it. I had to cut the bottom ball joint nut off, not a huge deal, but an extra step. Eventually I went to remove the top rod from the knuckle, and of course it just spun. So I cut it with the angle grinder and went and bought a new one. Then I went to separate the ball joints to remove the knuckle and broke my pickle fork. So I went and bought another, got the knuckle off, pressed the old ball joints out and the new ones in, install my new tie rod end, and begin putting everything back together. I reinstalled the axle, then the spindle, then the hub, torque the hub to the proper spec, which is a pia, then go to reinstall the locking hub and it won't go in. Turns out when I installed the spindle, some rust, I assume what was left of the brake shield, got between the knuckle and the spindle and caused the spindle to be improperly seated. So I pulled the spindle back off, tossed it in the bed, half assed put the tools away, and called it a day. I was soaking wet, dirty from being on the ground, and cold. The snow still hasn't let up.
On the bright side the hard part is done. I'll probably finish up tomorrow. Right now I feel like I got hit by a bus, and I just need to go to bed.
