Decided to get back around to this. I've had a lot going on lately but I miss having the truck at my disposal. It has been parked untouched since my last post.
I decided to start with fixing the broken radiator support mount. My cheap Harbor Freight Chicago Electric welder kicked the bucket about two months ago which is part of why I've been putting this off. I had been limping it along for a while but this last time it truly had waved the white flag. I was going to buy the exact same one again but it was out of stock at HF and I wasn't going to drive to another HF store for it so I went to Home Depot and bought a Century (Lincoln) FC90.
It's a nice little flux core machine. It's an inverter welder and runs on 110V. It's super light and small and very powerful for a 110V machine. Unless you are running it continuously for hours at a time, it's probably more than enough for most auto/home jobs.
Anyways I first removed the wheel and the front bumper to make some working room, then welded up the two cracks on the support mount. Then I fabricated two small gussets out of some thin bar stock, and welded them over where the cracks were. Then I wire wheeled a bit to remove some of the flux core spatter and gave it a quick coat of black Rustoleum from a spray can.
Welded, plated, painted-
Fender to door gap now back where it's supposed to be-
As for the water leaks, it has rained really hard several times and there has been minimal leakage into the cab. It poured for a half hour or so yesterday and there was only a very, very small amount of water inside on the driver's side. Passenger side was dry. I'm gonna call that good enough to put the dash back in and get this thing driveable.
I have a new cowl seal from Bronco Graveyard still in the box that I ordered when I started this mess.
Tomorrow I'm going to get a sword pinstriping brush from the local art supply place so that I can touch up around all the seam sealer I put on. Not sure how far I might get but I'll update. It only took me a day to pull the dash, it shouldn't take me much longer to put it back in.
