My full Build to Date!
Re: black int. , stereo etc. updated more pics !
got the rear interior together and a scoop ! ( its just sitting on the hood for now....) i had the retractable belts f up twice on me after a few months so i went with all regular lap belts in the rear..
Re: black int. , stereo etc. 200 4r questions
hey ive put this list together and was wondering if there is anything else i should look into. i thought of steels and the 10 tooth drive gear after but have added them. Thanks Dave Gettin closer to the time to drive it again !!
seals , Gaskets, rings, pan gasket, front, and rear seal kit , , filter , Clutch kit , High energy band And front pump bushing, . Hardened front stator , The hardened drive shell, - 2200 convertor -on sale this time of year,
Re: horners getting dark... black interior pics
horners85regal said:
carb is next to go for sure. new heater hose, just workng away at it.....
nice setup, I did 4 15's I wish I would of went 12's
hood scoop in progress even while im stuck out in Mississauga !
Re: black int. , starting the hood scoop
that's what I have to work with... im thinking that maybe if I use that panel bond on clean steel then set the scoop into it I may have a chance of making it work. Ill also use some fun fibre glass matt to mould it in. If anyone has any other suggestions or advise on this please chip in ive heard sooo many cracking stories. My other thought was to clean about 4" where the scoop sits and then use the fibre glass matt lat it out all around and then set the scoop into that and mould it in with the matting....
Looking good, give ya credit for going with the scoop you have. I myself went with the cowl hood, but that will look sweet when done. BTW, those wheels make your g look bada$$ 8)
thanks ! just hope I can keep it from cracking.... I also thought of using the stock air filter housing with this,
http://www.ebay.ca/itm/K-N-X-STREAM-TOP ... d7&vxp=mtr
if im right I can extend the sides up and seal to the underside of the hood and have the filter actually in the scoop.... just thinking out loud right now I can measure and check into it more when I get home
