My full Build to Date!
Re: 1985 regal, 2 year budget build !!
Excellent work!!
I'm not a fan of cowl hoods and cringed when you were going to put it on but it's come out really good!!
Additionally, I was hoping to see more on the sub install. 4 free air subs and that one amp? Can you provide any more details and pics? Looks great so far!!
I also love what you've done with the interior. Very sharp!!! :mrgreen:
Sorry havnt been on for a while, ill up some more pics of the subs and suff....
specs for amp,
6 x 50W @ 4 ohms
6 x 100W @ 2 ohms
3 x 200W @ 4 ohms bridged
THD: 0.02% (4 ohms)
Freq. Response: 4.5Hz ∼ 100kHz (±0.5dB)
S/N Ratio: 110dB
Damping Factor: >500+
Max. Current Draw: 100A
Fuse: External 80A
Dimensions: 19.75" x 8.98" x 2.24" (50.2cm × 22.8cm × 5.7cm)
I have my 4 subs running stereo, 2 ohms off the sub channel, the 6x9s are in the rear deck running of the rear channel, and i have the 4x10 speakers in the center consel on the front channel of the amp, plus the 3 1/2 dash 2 ways are off the deck.
Ive had the amp for ever and it takes a beating and iss sooo loud and clear its un real. Gives me goose bumps on certain songs lol. Its like being at a concert. I listen to everything and love the set up.
My problems now are . . . . . . seems my engine is sh*t, im running on 6 cylinders. had my transmission rebuilt and at wot shifts approx 6200 rpm, my engine on its good days nose dives at 5000. My speedo cable is sticking, i think my heater core is starting to leak, ( i can smell it ) my vacuum switch for torque converter is shot so i un hooked it. Been working soo much that i havnt really done anything ith the buick but drive it. On the up side the ac is nice and cold lol and i have stuff to do when its off the road again this winter ! :blam:
K i ordered my speedo cable now that i see my new 27 tooth driven gear is fawked. I also found ebay has the 27 tooth drivens on there !!!! Grab them while you can ! i ordered 2 lol. Got my heater core swapped out and thats all good now.
here is a pic of the subs wired up and done just have to slam the back seat back in.
I remember seeing this online and couldn't remember where i saw this setup...glad i found it because I am going to model mine to this exactly! Thanks for the info...
Re: 1985 regal, A new heart !
fully rebuilt 355 cu SB Chevy engine . All new and fresh . Although designed for street use it received all the same prep work as our all out race engines . The block is a early 2 bolt , bored and honed with a deck plate , alighnhone mains , decked square .
Fully balanced rotating assembly , Flat top pistons , Molly rings , HI Pres oil pump , pick up , steel collor drive , double roller chain .
Brand new pan and timing cover . Comp Cams CS 279 H-107 Thumper series cam shaft , 441 casting 2.02/ 1.60 valve cyl. heads . Has all new bronze guides , Comp valve springs , HT locks and stainless roller tip rockers .
It is assembled with all new head bolts and hardware and premium graphite gaskets.
