Please elaborate. That is a new one.The engine was built in 2005, sat, and now it needs valve springs.
Well there is a thought that when a spring sits in the open position for long periods it loses spring pressure. The best thing to do is pull a spring and check the pressure. However on the flip side of that. I’ve seen it have no impact. What I have seen is big block chevys with heavy valve train when the cam companies recommend bare minimum spring pressures that work on install and then break in and lose pressure and become too weak.Please elaborate. That is a new one.
Ok I can see that. I also can see this go down the rabbit hole. I did try to start this engine every year at least once and run it up to operating temperature. The longest it sat with out being started was two years.
Like I said it’s not a big deal to pull 2 springs off a cylinder and check them. GENERALLY what I have found is heat cycling and valve float do more to spring pressure than just sitting open for periods of time. They are supposed to be spring steel, so they are designed to run at a pressure and position. As long as you don’t exceed this they don’t fatigue. I hope I’m explaining so it makes sense. Kinda like if a spring has a million cycle life span, holding it open to a normal position is still 1 cycle.Ok I can see that. I also can see this go down the rabbit hole. I did try to start this engine every year at least once and run it up to operating temperature. The longest it sat with out being started was two years.
I do have tail pipes out the back.So which Flowmasters do you have? And do you have tailpipes?
