I have a TrueTrac in a 9 with 3.70 gears. It works well, but can be a little noisy when it hits both wheels.
Thank you. I would be interested in hearing more about your buddies car and what he did. The seats are pretty comfortable, but would not be for long drives. I don't plan on taking this car too far from home. A speedometer, windshield wipers, power steering, and maybe heat would be more important than the seats right now.Nice car, my buddy has a red 69' Nova with a 632 BBC his was a race car turned into a street car.
I don't know how comfortable those race seats are but you might want to consider changing them for some nice adjustable bucket seats with some bolstering.
Less gear and full exhaust will definitely tame it down and make it more enjoyable to drive.
I agree with what you are thinking, but once you hear it run the cat would be out of the bag. The alternator is not lined up very good and the single v-belt at high RPM is not going to work very well. When this car idles in gear it lurches forward with the lopes of the cam. Solid body mounts and motor mounts. It gets my adrenaline going when it bounces off 10000 RPM.I like the cheap valve covers and alternator bracket. If anything, I'd head in a more sleeper direction and hide the nitrous solenoids. By all appearances the car is a cruise-in queen. I'd never suspect legit 700hp racecar. I'm guessing it sounds pretty serious.
Thank you.Subscribed. I love that you still have your Dad's car and get to enjoy ownership of it and wrenching on it. It's a great looking car. Still the best part is that his car, something that he put a lot of himself into, is still around and in such great shape.
I look forward to your advice and comments. I find them to usually to be pretty sound advice and I know you have a lot of experience in this stuff. To answer your question would be no. This car does not even have a 100 miles on it since I put it together. Knowing my Dad I am betting on the converter being a cheaper one. Knowing what a good one cost I am sure he cheaped out on it. I am leaning more to 3:70 gears now to be more on the safe side.Converter slip won’t be a concern with a well built converter. If it doesn’t lock all the time below lockup rpm during steady state driving, then you need a better converter.
I used to be concerned about the same issue until I began using better converters.
My current converter will stall to 3800, but I cruise at 2500 and the rpms never waiver unless I increase throttle a noticeable amount. And if I stand on the throttle, it will flash to the low 4’s. But it doesn’t like trying to cruise much below 2000 rpms - pretty much related to HP and cam specs.
Regarding the gearing, pick an rpm where the motor will cruise at (hopefully you’ve driven it enough to know this), and then pick a gear that will keep the rpm in that range at highway speeds. My guess would be aim at 2400-2700 based on what you’ve told us about this motor - but that is a guess only.
Looking at those chips and hearing the pinion was loose - sounds like you made the right decision to pull it apart - something unfriendly was occurring in there.
Good luck and keep us posted - Jim
You could always weld in a stainless braided flex pipe to make the bendI cut slits in the extension pipe and tried to aim it back, but that was a fail.
The engine is not broke. It runs good. ABS module took a dump. Ignition switch seliniod lock not working right and I broke the tilt column lever.The 3800 W body broke! Is that even possible!?!?
Nice to see the car being given a new life
That is a option.You could always weld in a stainless braided flex pipe to make the bend
Exhaust Flex Pipe Stainless Steel Double Braid 3.5" x 6" w/ Ends 11" OAL | eBay
That is my plan as of now. A ball socket pipe in 3 inch would work too.I’d cut the header pipe and re-weld it. Looks like you need about 3-5 degrees of bend to resolve all issues.
