It has been a busy past to weekends working on the car. So I found out that I needed a long nose water pump to go with the new brackets. So I bought a new pump. I masked up the front of the engine and did a little painting.
Then I mounted the new belt drive system. That is when the snow ball rolled down hill. I researched for a couple hours trying to find electric fans that would clear the new water pump and pullies. I even took the fans off the Monte to test fit. I ended up going to my mom's house and scrounged around. I found a 12 inch fan and some sheet metal. So I built my own.
I robbed a 10 inch fan from the previous setup. So it has a 10 inch fan and a 12 inch fan. I don't think it turned out too bad? Last week I made up a fan drive board and wired everything thing up.
I made it so I can hide it in the fender.
I ran the car to get the coolant level back to normal level. After running the car for half hour I found the fuel gauge is still loosing pressure, even after I changed the seliniod to a relay. I did a little research on the pump. It is Berry Grant 280 pump. You can only run it with out a return fuel line for short periods. (Drag race only) I found out there is a speed shop 10 miles from my house on Friday. They are also open to 4:30 on Saturdays. I had to watch my kids till 2 and then I could leave. I went to Story City to the speed shop. It is mostly for stock car stuff, but they have a lot of inventory. They didn't have a return pressure regulator for a carb on hand. Well shoot. So I ended up buying a smaller fuel pump that can be dead headed, but not really recommended. I bought a pump, an fittings, hose, and a filter for 130 bucks. I got a little side tracked on the way home and did not get to work until 8:30. I worked to 11 before I quit. This morning I got up and got to work at 8. Got the car running. Had to fix a couple fuel leaks and finish a few loose ends. I washed and cleaned the car all up and made the car show at 11:30.
This show was only five miles from my house, so it was a good maiden voyage. The wife and kids showed up and so did Grandma.
It was a good time.
