Dug into the wiring & found out a few things from the manual & powering things up with test leads again. One thing is the light green wire thay will run to the PRNOD21 switch in a W-body only needs power if the trunk relase is being tied in. It's ment to only allow power to the trunk release when the switch is in the park position. The pink/black wire is part of the lighted entry/exit feature to ground out the feature when the key is in the run position. This will be useful if I can figure out how to work the feature with the blue wire. Then with how the tan wire is shown it would need to replace the tan one in the stock harness for the divers side with it only being left connected to the passenger side. For this I'll unpin & insulate the terminal & run a new wire in it's place. If it wasn't for the odd reason for an easy way to reverse this I'd just make a new wire but this may change with if I come to my senses.
