need a source for tailgate cable swage eyes
12,168
9,778
As the title says, I need to find duplicate factory type tailgate cable swage eyes. I would like to shorten the tailgate cables, due to the tailgate almost resting on the bumper when it's fully open.
I appreciate any thoughts and possible sources for these.
12,168
9,778
Reproduction El Camino cables - longer than wagon cables?
Quinn,
If I'm not mistaken, the El Camino cables are slightly longer. I remember a member needed a pair for his wagon, and another member offered him El Camino cables. After he had received them, he noticed that they were in fact longer.
Ribbedroof
4,914
7,035
Wellston, OK
Three choices as I see it
Try an overhead door company, the drum cable ends may be similar
Use die grinder/cutoff wheel to split swage lengthwise, shorten cable, weld/braze back together, grind/dress ferrule, cover with shrink tube
Relocate gate end to under one of the latch bolts. I would probably use a slightly longer bolt with a short length of brake tube to make a collar for cable to pivot on
All I can think of right now
airboatgreg
2,870
3,116
Had same issue with my El Cam. Someone installed wrong ones. I bought new on Ebay and they are the right fit
7,989
18,702
Jack, maybe you could just match up some shorter cables?
79 USA 1
1,065
2,039
Cheektowaga, New York
Quinn,
Jack,
You are correct! I had sold that set to abadwillys and it turned out the ends were larger on the El Camino cables and could not be adapted to the wagon. I believe they were also around 1/4 inch longer in length.
Sorry to say you have to find the wagon specific ends and see if they can be made in custom lengths.
Bob S.
12,168
9,778
Jack,
Bob S.
Bob,
You were the person I was thinking of. I forgot that you sold yours to Bryan and that the ends were actually larger....I forgot that part of it.
Thank you for coming forward.
