If thats the case,cheapest would be a used 4.3.Ok, that being said do you think the 350 is the correct choice for what I'm looking for? Really looking for consistent everyday driving as opposed to power and speed.
305 might be a good choice if you go used. Will give it more pep along with better mpg. And if you keep the TBI a 4.3 has the same injectors as 350 so it'd be slight tb upgrade for the 305. And a Lotta places you can get a 305 nearly freeOk, that being said do you think the 350 is the correct choice for what I'm looking for? Really looking for consistent everyday driving as opposed to power and speed.
In my experience a used 4.3 ends up still costing more. Newest direct swap 4.3 is 22 years old. Also 4.3 s10s(likely donor) tend to be some of the most abused vehicle's. Basically a used 4.3 is a timebombIf thats the case,cheapest would be a used 4.3.
I was thinking,smallest labor costs.In my experience a used 4.3 ends up still costing more. Newest direct swap 4.3 is 22 years old. Also 4.3 s10s(likely donor) tend to be some of the most abused vehicle's. Basically a used 4.3 is a timebomb
Then I agree with your post,for getting a used 305. Usually cheap,good on gas,and able to get something a little newer.Only difference in labor is about 30 mins to swap motor mounts
Cost difference between going 350 or 4.3 is MAYBE $100. New 4.3s can be costly. As long as you get the right manifolds the only parts you HAVE to buy are the motor mounts(<$20)
