I would do the 454. You can build a low compression oval port engine and go in the 12's without much effort.
100 shot with the 781s strip dominator ?I would do the 454. You can build a low compression oval port engine and go in the 12's without much effort.
That wasn't even a option I was just saying I got one hahaShould I use a 283, or a 454? cannot be a serious question. Let's see some pics of the car and that tunnel ram.
240 may even be too much if it’s around 9:1 compression. I’ve seen a lot of stock head motors with about 10 degree splits @.050, i was quoted a 229/241 cam for a project I’m doing.What kind of cam I was thinking 550-580 range 240 at 50 range?
The motor has 30 over flat tops I was gonna have it zero decked and small domes have everything balanced goal is to be around 10-1 maybe lil less I want a pump gas motor240 may even be too much if it’s around 9:1 compression. I’ve seen a lot of stock head motors with about 10 degree splits @.050, i was quoted a 229/241 cam for a project I’m doing.
Plus you won't have to rev the piss out of them.
