Need some advice
Texas_85
n00b
Aug 11, 2020
4
Finally got a lift in my garage so I can start getting my 85 cutlass back together. I currently have a new 383 ready to by put in. I want to do this thing right this time and hoping I can get some advice on what transmission and rear end j should put in this build. Car will not be a daily driver, something that I can take out every so often for a cruise and be able to take it to the track and have some fun in. I was originally thinking of a th350 but now thinking a 700r4 might be the way to go with a ford 9” in the rear…. Looking for any input. Built a chevelle when I was 18 and thing was a slug because I didn’t know how to pair things up properly so this time around I want to get everything I can as far as hp/tq is concerned
ck80
5,744
9,121
Well, you're on the right track with your questions on 'pairing' to get the most oomph.
You say you have a 383... is it something you bought or built? Curious because wondering if you have a dyno sheet or if someone else may have a similar engine where we can tell what your power bands look like.
Once you've got that info, next question is your rin/tire combo, and how/where you plan to do most of your driving. In town off the line 0-50mph or lots of highway.
Then you add your transmission choice, and, you can use a calculator to pick your rear gearing so that at the given desired mph ranges you're hitting the right spots in your power band.
melloelky
4,160
9,568
mass
he's rite^^with the motor done build the rest of the combo around that.converter,intake.gearing,tire size are all relative.get a few options from company's on what to run and make your selection from there.example not all converters are created equal.i polled three companies and made my decision from there.
scoti
1,974
3,396
Texas
If it's just an occasional use (sunny Sat/Sun) type of ride, a built OD trans will yield little return on investment as far as usage. How much highway driving do you anticipate?
Spending money on a better TH350 or TH400 would be smarter if the vehicle see's track time vs. extended highway jaunts. Match the converter to the cams range & then match the gearing to the converter.
TH350/TH400's have better gearing ratios vs. the 700-r4.
The 200-4r is similar to a TH350 but w/OD. Harder to find vs. the 700-r4 but it should be considered if thinking about automatic OD transmissions.
scoti
1,974
3,396
Texas
Nobody mentioned the 4L80e yet - you'd need something like this to make the electronic trans work: https://www.summitracing.com/parts/tci-302820
I didn't mention it because of the high cost. I figured it might be worth mentioning if he responds w/the need for an OD set-up if he plans on accumulating highway miles on his weekend jaunts.
Building a 4l80e isn't cheap. A decent converter for one is definitely not cheap. Since most 383's are likely carb'd, it didn't seem worth mentioning the 4l60e/4l80e options because of the added cost for controlling the trans.
doood
Amateur Mechanic
Sep 24, 2020
574
786
Since the guy has a 9-inch rear, the 700-R4 would be the weak link. Considering he just bought a lift he might have the $700 for the transmission controller. Three speeds are worthless if he wants to take it on the highway and he wants to have a good rear gear. If it was my car, I'd put a 4L80e with the controller, or would have kept the 7.5" if I had to go easy on the 700r4.
scoti
1,974
3,396
Texas
I agree. I wouldn't purchase one to use.
Not sure he actually has a 9" though since his statement mentioned:
It can be interpreted as a 700r4/9" combo he was thinking of purchasing vs he has a Ford 9" already.
86LK
1,971
2,038
interesting because I know there is not that much that you can change in the system. I currently have a 305 with 200-4r in my 86. I recently got lucky finding an 8.5" rear from a member here. I do have plans to put a 383 in it eventually (block in the garage) and it would be a mixed usage, highway city driver. where would I find an explanation on finding the right converter for the plan?
scoti
1,974
3,396
Texas
I'm not sure what you mean by "in the system"?
The converter needs to match the cam profile & rpm needs of the cam/heads combo to be most effective. If you have a stock converter but a cam w/>240° duration & 210cc heads you'd be leaving a lot on the table performance wise. Same would be true if you had a 3500 stall speed w/a stock cam/heads/<3.0 geared rear end w/>26" tires. The combo needs to compliment each other.
