Anything with compression is a better engineIt may not be the original engine? I'd guess that it is but its possible its not. Vin says its a 84, Door sticks says manufactured in 83 too. Is this a better engine?
Alot of them did ,you probably got a "HO" motor that's what a ss should have had so that explains them flat tops, installing a big block will take car of them manifold bolts alsowelp I torched them off. Got them off, and one head off. I didn't know some 305s came with flat top pistons?
Your be the first to know if you messed anything up keep at it good luck and don’t forget the zinc oilIt seems to have a lot of compression even with it running as rough as it was. I will finish getting heads off and clean the motor the best I can. This motor had acorns, sludge and dirt in the motor. Not bad, but you can tell it leaked or burned oil and they just poured a quart in it at a time. My guess is it had a valve cover leak, considering all the oil on the bottom of the valve cover near the exhaust manifold. I'm willing to bet once I get it back together, it'll run damn near perfect. Hopefully I didn't mess anything up with the wiring, they were old and brittle.
