It all depends. Did the turbo seal go out or intake impeller? It is a turbo engine so a little more than a naturally asperated engine. Unless it is a 78 or 79, then probably a boat anchor.
No clue, about the turbo. Its a 79.It all depends. Did the turbo seal go out or intake impeller? It is a turbo engine so a little more than a naturally asperated engine. Unless it is a 78 or 79, then probably a boat anchor.
Worst case I would say core value. This way if they are a total lost there would be some sort of value.View attachment 70815 View attachment 70816
Got the engine pulled today. Any idea what this engine trans is worth? Turbo is blown. But have all the pieces that came with the car. Can't say that's complete but looks to be mostly there
Send me a PM, I have the intake setup, not in great shape but I have it, the box as well.Engine may be of interest to jeep guys for an offroading machine. Probably your best bet.
Trans... Probably not so much use, keep it for a core depending if it's a th350, or scrap if it's a th200c....
As an aside, if/when you get to the point I may be interested in trading you something (s) for either the complete air intake (bonnet, tube, airbox), the small control box and harness that would've bolted on the fan shroud, and the factory rims... depending on condition.
I keep trying to quit hoarding and accumulating, but, those are the types of things id still probable wind up doing something with. Then again, would have to mail back and forth between georgia too...
Well I appreciate the information. I could not find this info and was slightly curious. Glad I didnt decide to persue building this engine since its not interchangeable.The early years have a different head and intake than the 80-84, and will not interchang. Not worth much, couple hundred bucks maybe.
