You're more than welcome. Glad to see them help bring back that car.Also wanted to say thank you to Texas82GP for the new cross member mounts
Yep, that's one I was using. My only real complaint is the heat range selector; it's got detents. It would be much better as a smooth sweep. There are instances where one is too cold, but the next step up blows through.This the Lincoln I was looking at
Lincoln Electric Weld-Pak 140 Amp MIG and Flux-Core Wire Feed Welder, 115V, Aluminum Welder with Spool Gun sold separately K2514-1 - The Home Depot
Finish any home project, farm repairs or basic auto body welding easily with this Weld Pak Wire-Feed Welder from Lincoln Electric.www.homedepot.com
Harbor Freight says there stuff is better than everyone's else's so i would go with theirs!!!!
I know years ago the biggest issue with HF brand mig welders was their consumables were specific to them where most brands can use readily available Lincoln ones.I’m open to hearing if anyone has used it and had good success.
