Just ordered a Scanmaster G with data logger so it has fast data feed and blue tooth connect. Almost $600, hope it was worth it. 😓
Unfortunately true I'm learning. I kinda knew that going into it. I think this particular purchase just annoys me because at the end of the day it's still basically just 1986 technology... My $100 smartphone is probably 1000 times more powerful than anything that ECU can do and just had to plop down all that cash on it lol.There is nothing cheep about a Buick turbo six!
Was thinking about getting the MS3 pro plug and play ECU for a turbo Buick. It's about $1300 but now that I already pulled the trigger on this setup I'm going to stick with it for now. Still significantly cheaper and hopefully (hopefully) will be all I need computer wise. I know it's capable of more performance than I'm going to shoot for, as one or two people pointed out in this thread people are doing mid tens or better on the stock computer with a chip, and scanmaster/Data logger, so it should in theory be more than good enough.You can upgrade the technology, but that cost a lot more money. You can go to a Holley ECU for around 2 grand. There are cheaper options, but if you are going to do it might as well do it.
Well, I've been running these cars for 20 years, and all I have is the regular scanmaster. You don't have to step right up and buy the most expensive stuff. I'm under the impression by reading your posts you have quite a lot of other stuff to take care of, and maybe that money should be spent more carefully.
