No heat!
Agamemnon
n00b
Jan 24, 2009
I have a wierd issue with my heater recently. When the temp slider is on the left side(cold), the air comes out normal and blows out strong when set to max fan. But when I slide the temp to the right(heat), the air flow is very weak and little heat. The air comes out luke warm at best.
This is for my 80 Malibu classic that has AC. Any help would be much appreciated. These cold Seattle mornings suck.
dan2286
2,233
4
Cleveland, Ohio
Does the fan sound like it is blowing on high when it is set on hot? I believe that the hot/cold air is controlled by a cable operated blend door. It sounds like that might be jammed or broke in some way.
megaladon6
4,006
15
Danbury, CT
it's a problem with the doors inside the unit. it sounds like the external/cold air vent is working fine and closing when you go for heat, but the hot air door isn't opening properly.
Agamemnon
n00b
Jan 24, 2009
The fan motor does sound like it's blowing at max.
Is it possible to check the blend door without removing the dash?
Cutty1
412
2
metro detroit
not getting hot hot heat
would the water valve not make hot hot heat?
Cutty1
412
2
metro detroit
cause i get heat out the vents now but only like 2inch of air lets say blows out and it dont even warm up the car even driving for awhile.. i know i need to replace the high blower relay but why arent i gettin hot hot heat ? there's vacuum i hear it closing the door and opening, and switching doing what's suppose to ..
SV6 REGAL
146
Ont Canada
Is there a valve on the heater hose under the hood (out or in).On my Regal someone replace that controller with a on/off valve to let the heat go to the heater.
