CCC and older non CCC (vacuum advance) HEI distributors used the same 12 ga PINK IGNITION feed wire under the coil cap so that part should need no rewiring. That wire comes directly from the IGN switch on column FYI.
Like pagrunt said you need to connect up the vacuum advance to manifold vacuum source for that part to work.
