OEM Weatherstrip
Vortectim
13
12
Hey guys,
So I just encountered a bad experience with Softseal door weatherstripping. I noticed the originals had a plastic center at the ends of the strip inside the foam, the new ones obviously do not. The new ones have a washer built in that doesn't do a damn bit of good and they ripped from having to be stretched out a bit to line up with the screw holes. Is there another company that makes them "exactly" like oem with the plastic built in, if not then where can I buy some GM replacements that wont cost me over $500?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
do you mean SoffSeal? If I were you I'd contact the company to ask them what they can offer to solve the issues you have with the seals.
https://www.soffseal.com/terms-and-conditions
Warranty
SoffSeal products come with a Lifetime 100% satisfaction guarantee. SoffSeal will issue a replacement part for any product needing to be replaced that qualifies as a warranty item as defined within these terms.
An item can be warrantied if there is evidence of a manufacturing defect or wear and tear. We stand behind our Lifetime 100% satisfaction guarantee.
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,510
4,906
Rolla, MO
*nobody* makes replacements with the correct plastic inserts. If you can find OEM stuff you're looking at $$$ if its even any good.
If I'm wrong somebody tell where to get them lol.
Ribbedroof
4,904
7,012
Wellston, OK
Warranty
Pardon my language, but they don't give a damn.
I had an issue with some rear door weatherstrips on the wagon. No response via email, and when I finally got to a live person, they really had no interest in the problem, and told me I would have to go back to the seller to get it resolved. I explained that there was no issue with the seller, the part was incorrect for the application listed.
Long story short, Mike's Montes made good on the situation, despite them having no control over the issue.
Postscript to the whole thing is that they don't seal the doors worth a damn....I'll be replacing them with Metro. I used the Soffseal because I had bought roofrail strips for a coupe that worked well. Maybe they just don't give a damn about crewcabs and wagons?
565bbchevy
9,614
12,683
Michigan
I ended up going with Metro Supersoft but they don't have the plastic either but I did find if I scuff up the mounting surface of the seal and the corresponding area on the door and use 3M weatherstripping adhesive I end up with a very good bond even though you have to stretch the seal to fit correctly.
  • Useful
Vortectim
13
12
This is where I got with Steele. I told them to start making them correctly with the inserts and I could bring hundreds of customers willing to buy them. Anything without the inserts is just garbage!
69hurstolds
8,198
17,599
And they called me crazy for stocking up on those "over-expensive" GM weather-strips back in the day….they weren't cheap when I bought 'em, relatively, but they fit and function like a dream.
NOBODY makes them aftermarket with the end plastic pieces or the squiggly wire reinforcement (where applicable). If they could, I'm sure the price would be adjusted up accordingly. Plus, the hardness of the aftermarket seals are much denser it seems and don't accommodate with enough crush in my opinion. Plus, it is my opinion (no proof) they simply try to get over by molding Cutlass ends on Monte Carlo door seals.
I've only had one experience with aftermarket seals years ago after repainting my 84 H/O. Tried soff seal door seals and they were nicely made, but a tad short. Even with adhesive and minor stretching, they still fit like crap. Then I had to slam the crap out of the door to get it to close. After about a week of that crap, went to GM seals and never looked back.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
No my roofs where pretty much perfect
but if they fit like the doors did I would recommend it
