Oil gauge pegs at 20psi
10,568
14,303
1978 silver gauge, 301 engine. Only goes to 20psi no matter what. Sender or gauge? What is the procedure to test the sender? I have a multi-meter but I never used it to test an oil pressure sender. Mine is in such a bitchy spot want to test first.
8,826
7,779
Probably the sender. I had that issue, went through at least two senders on my 78 1/2 with factory gauges.
10,568
14,303
How do you test it?
9,184
15,398
If I'm remembering right
How do you test it?
Found this
How do you test an oil pressure sending unit with a multimeter?
In order to test the switch you can connect your multimeter between the pin and the senders body. You should find the switch is closed while the engine is at rest. When the engine is running, the switch should open. As you can see this switch has only one pin, so the switch works between ground and the pin.
10,568
14,303
That sounds like it is for an idiot light sender. Isn't a gauges sender a variable resistance?
  • Useful
10,568
14,303
AC Delco part number for a gauge sender? The ones I'm seeing have a screw fitting, I need the blade. Normally I would go with Standard, no longer. EDIT: Got it: D1829
10,568
14,303
SOLVED! Still don't know how to test the sendor but I tested the dash gauge. I removed the wire at the sendor and grounded it then turned the key on. It pegged at the high end of the gauge. It also bounced wildly so the dampening fluid is gone. I scrounged up a new sendor from my stash of parts. It is a KEM made in USA so it should be a good one. Started the engine and she's back to 60 psi. Done.
