Mathematic said:thank you...for the info. I was hoping someone would chim in on that photo.jmt455 said:I know you are looking for help with the oil leak, but I see something in the first photo that you might also want to fix.
The cross-shaft that comes from the transmission shift lever to the pivot bracket on the frame is missing a spring, plastic bushing and washer. The plastic bushing sits in the "cup" area on the frame bracket.
If you have a column shifter, it's probably feeling pretty sloppy with those parts missing.
I bought a replacement kit from Inline Tube. You can get them from a variety of suppliers.
I actually have a floor shifter and sometimes the ignition gets stuck and i have to twist the back of the steering wheel to get it released.
do you have a pic of it intact?
I'll try to shoot you some pix tomorrow.
I'll also scan the linkage adjustment procedure from the Factory Service Manual...it takes some patience to get that all working perfectly.
