Where are you located? I have an uncut 455 I picked up eleven years ago for a project that went another way...
$100 is a steal, so you can afford to play with it a bit. I like to do what I used to call a "$100 rebuild" but it's a lot more expensive these days. First I would do a compression test to see if it was worth even doing. If I got good compression then I'd pull the heads off just so I could de-carbonize the head combustion chambers and piston tops with a wire brush on a drill and a scraper for the real crusty buildup and use new head, intake, and valve cover gaskets to button the top end up. Then I would change the oil pump and oil pan gasket, timing set, front seal, water pump, thermostat, fuel pump, and motor mounts. With the pan off, a neoprene real seal is a good idea and for a Buick a high volume oil pump kit is also a good idea. I have used fully grooved main bearings too so I could be sure oil got to the mains- Buicks oil the cam and lifters before the crank. If you know the carb is a good original, reuse or rebuild it, on an unknown or missing carb I would just get a rebuilt. Rebuild the distributor or get a rebuilt, plus new plug wires, cap, rotor, and plugs. A lot more costly nowadays, and you haven't even done any machine work, but if the engine is sound to begin with, now you really have something.
The front seal comes with the timing cover set which is included with the whole engine set. That's a lot for a thermostat. Try RockAuto.com and if you order from them don't forget to include the 5% discount code. You enter it where it says "where did you hear about us?" and this one is good until Nov 12, 2015. Here it is- 2AE786C07A0A14.
So I had some time to take valve covers off. Heads are stamped 1233472. Are these good heads worth rebuilding?
