Old School Meets New - Supercharged LSA into Grand National
DeltaT
125
Re: Old School Meets New - Supercharged LSA into Grand Natio
Thanks for the link!
Finished the front frame paint:
dsc03100-jpg.216205
dsc03103-jpg.216206
And started test-fitting:
dsc03107-jpg.216207
dsc03109-jpg.216208
Then slung on the driver's side brakes:
dsc03113-jpg.216209
dsc03115-jpg.216210
Big day!
Steering box, front anti-roll bar and passenger side test-fit in the next couple days. By then my new centerlink should be in.
Jim
-83MONTESS-
4,570
967
Bellevue, Ohio
:drool: Nice!!! What kind of paint did you use for the frame?
85GPLef41
2,210
159
Colorado
NICE work!! my GP's next front suspension rebuild will include the sc&c adjustable arms.... and spindles.. :D
DeltaT
125
Thanks, guys.
The paint is Eastwood's Underhood Matte Black aerosol. So far I used 1.5 of 2 cans. For primer I used Rustoleum Etching Primer which worked fine and is way cheaper than the Eastwood. I like the Eastwood top coat as it dries fast and has a classy, understated look.
Now I'm trying to get at the computer wiring harness pass-through without removing the metal part of the fender. Anyone have any tips?
Thanks,
Jim
JAWSS
Sep 23, 2009
64
Ft.Hood, Texas
Man, this is an awesome build with high quality parts and work throughout!! I would really love to give my 84 MCSS a similar update soon. Keep up the good work!!
Clone TIE Pilot
3,903
2,682
Galaxy far far away
With that much power, I hope you replaced all the body mount bushings and installed the "missing" mount bushings. Probably going to need a rear seat brace and rear LCA mount gussets.
DeltaT
125
All ready to install. I always use the HRPARTSNSTUF gussets on the LCA mounts on these cars - cheap insurance!
Jim
Clone TIE Pilot
3,903
2,682
Galaxy far far away
That's good.
DeltaT
125
Fitting in the SpeedTech chassis brace and Flaming River 670 steering box:
dsc03123-jpg.216971
I'm covering stuff up with painter's tape until I know it is actually installed, mostly to protect the finish but it also reminds me that not everything is fully tightened up.
Ridetech MuscleBar also in test-fit along with the new steering centerlink and drag link:
dsc03124-jpg.216972
They clear each other by about 1/4".
From the bottom:
dsc03128-jpg.216973
And a shot of the anti-roll bar arm from the outside. It's very tucked into the frame - thought it was going to hit a weld that sticks out a little but it also cleared.
dsc03127-jpg.216974
So far the only bummer has been the SpeedTech chassis brace hardware and fit. The fit is not a bolt-on for my car, and that may be my car's fault. But the hardware they give you, without any instructions btw (although it's pretty easy to figure out), doesn't fit the car and doesn't fit the brace! They give you 7/16" HW but only 2 holes out of 6 are meant for it - the others are drilled AND POWDER-COATED for 3/8" bolts. So you either have to buy your own HW or drill out the new, glossy powder-coated finish of the your new brace. I need to call and see what they say and how their customer service is. I'll report back.
Jim
JAWSS
Sep 23, 2009
64
Ft.Hood, Texas
Very nice update Jim!! Hopefully Speedtech makes right on the odd fitting brace/hardware. Keep up the great work.
J
