Jeezycol said:FE3X CLONE said:Jeezycol said:So will my sensors from the 307 screw into the 350 so I can use the 307 harness?
You'll probably want to get an A4 manifold off an earlier 307 (non-roller engine) to use on the 350. That will make the swap much less problematic if your trying to keep the computer.
Personally, if you don't have to deal with emissions or inspections, just unhook the wiring harness and tuck it up along side the passenger fender. Then get a '74-'79 Q-jet and HEI as mentioned above. Bolt on and go.
The other issue with keeping the computer is your going to need a place for the O2 sensor. You won't be using the exhaust manifolds from the 307 so you'll need to have the 350 manifolds modified (drill/tap or weld bung) for the O2 sensor.
Oh ok. I really would rather go without the computer so the engine compartment will look cleaner and less clutter. But the only thing that has me intimidated is the thing about the trans lock up.
As long as you have decent mechanical skills and are okay with electrical, kits are not very hard to hook up. I believe the best kits come with a pressure switch and a vacuum switch to keep the torque converter from locking up under part throttle. It looks like painless makes one of those style kits, but not sure on the price.
