84Hurst/Olds said:Yes. You can unbolt EVERY bracket off of your 307, and bolt them on to your 350. They have the same external bolt holes on the front of them. I have the brackets (including the ac) from a '84 307 bolted on the front of my '69 model olds 350.
CamaroAdam73 said:I have a question, i just bought a 79 Trans am with a 350 rocket, and the fuel pump has the line in/ out's on the top of the fuel pump I'm sure yall know what I'm talking about. It i just cap off the fuel return line will this cause problems?
DoubleV said:CamaroAdam73 said:I have a question, i just bought a 79 Trans am with a 350 rocket, and the fuel pump has the line in/ out's on the top of the fuel pump I'm sure yall know what I'm talking about. It i just cap off the fuel return line will this cause problems?
Why not just start a new thread......? :?
Jeezycol, what is your budget? Are you planning on getting the proper parts and machine work done or are you planning on just doing a 'hillbilly rebuild' ( aka re-ring, re-gasket, clean, slap it all back together and just assume everything's fine)?
Don't remember if you said if you were going to stay on the computer or not with your new engine?
Search the internet for info on cam specs. Too much to explain here, but there's tons of info out there.
