Peter said:
if you are leaving the computer you will be leaving everything in tact. all the random stuff like egr solenoids and all vacuum lines and i would even be leaving the air pump. it will definetly make the process a little more hectic getting all this stuff back in place but its possible. all of it will bolt up from the 307 to the 350
This isn't really the case. I made a detailed post on what you can and cannot remove when using the CCC system;
viewtopic.php?f=3&t=26382
Jeezycol, whether you want to retain or remove the computer, make your decision based off of facts and not peoples perceptions on how they 'think' the CCC system works.
I think you should retain the computer. It makes the swap easier, not harder. If you want to dump it at a later date for whatever reason, then you can do so. The trick is, is to dump all the $hit you don't need on your car NOW before the engine swap. Read the above provided link.
