Olds 455 With some rust in cylinder
Wesleey
13
4
What’s your guys opinions I haven’t really scrubbed with more then a cloth with some oil on it I personally think a hone would clean it up enough block has been bored .30 over allready in the past so trying to avoid making it any thinner/buying pistons ect only 2 cylinders are really effected that’s why only posted pics of them
DRIVEN
8,075
14,536
*CENSORED*
Ball hone. New rings. Do work, son.
Reactions: 6 users
MrSony
6,831
6,741
Des Moines, Iowa
Yep. Hone new rings. Make sure to gap them and imo wouldn't have the gap towards any rust or pitting.
lilbowtie
3,460
3,965
Canton Mi
I have put some shady stuff together but that third pic is pitted BAD. I would have to sleeve it.
8,826
7,779
Melville,Saskatchewan
Honestly, those are an out dated, heavy forged piston with thick rings. A lighter piston with modern rings is a good idea on the 455. With big heavy, soft connecting rods and a big heavy crank in a marginal strength block. You should be able to go 60 over, another .030" on a good block. Hone it by hand and see how it comes out but an overbore or sleeve may be necessary.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,697
Spring, Texas
Picture fooled me. I thought that was just trash.
Gonzo1970
898
1,302
Send it...
-Gonz
SSpev
195
301
Pic is worth nothing in this case. i need to see it. Looks like fluid in 3rd pic to me. I'd try a hone. If it is above and below the ring reversals I'd run it.
