The complete how to. No such thing as hijacking this thread if we are sharing good ideas and solutions.
Variable speed fuel pump via holley(or any stand alone ems) - LS1TECH - Camaro and Firebird Forum Discussion
Forced Induction - Variable speed fuel pump via holley(or any stand alone ems) - Just gonna share this because it blows my mind people dont do this, or they have a standalone and still buy a 400dollar PWM pump controller.. Or worse a voltage controller This was done with a single wire from the...ls1tech.com
To answer your question about the second pump, its just a Y fitting and a -8 check valve on the 4303 side. Probably going to be on the frame rail.
Something like this.
Yup thats what i thought about with the Y fitting. However if i can run the pump in PWM format, hell saves me some money on a pump, lines, and fittings. However the the 4303 will run out of steam at about 950-1000 rwhp on e85, which the in tank pump a 255lph will give her a little more room to stretch.
If you contact MF, they’ll tell you it can be pulsed. Our partner we ran drag week with last year ran a 4303 pulsed for the entire week. I know two others locally, that are doing it as well. I have to admit though, there is nothing wrong with running both pumps, just the 4303 is an animal at full voltage. The biggest issue with them is the heat they generate due to excess pressure according to MF. Running them PWM slows the overheating down as well.
I am truly curious of how the fuel trims will be when the 4303 turns on in the dual setup. I know my return (#6) is not big enough, but my fuel pressure spikes having a second aem380 turn on at 6psi. It takes until 12-14psi to level out to 58+current boost - which is fine because I live at less than 18 psi for about 1-1.5 seconds.
Sweet, i did not know that and that is a awesome detail to have. I am too curious im assuming with a good regulator it should hold it fine, but you really wont know until you test it.
When you do have the spike in your fuel pressure, do you see that in your data log for AFRs? obviously rich is better than lean, i am just curious.
