I considered silicone and send it....Hack.
transmission surgery complete. Kinda....
Tore the pump to case seal so gotta pick on up tomorrow to be finished.
View attachment 159573View attachment 159572
But it is ready for trans brake goodness.
Had a conversation with Jakes Performance this morning, its their brake and I needed a few things answered. I discovered that I can run this full manual or full auto with nothing needed for reverse engagement. Thats kinda exciting.
Get a front seal from the trans shop tomorrow and this will be ready for install. Then I can start work on the cage install...
I didn’t know anyone had a Trans brake valve body that allows for full auto operation. Now you have me considering it as a winter upgrade.
Lol. think about it. I destroyed my trans once already.Will be needing your expertise when i tear mine apart! LOL.
Good to know that the D1 can be used in both auto or manual shifted. I assume that on TB in 1st then you'll have to shove in into drive to get it to work right? I know his D3 can be used in auto and you dont have to leave in first.
If I have this correct:
The D1 brake valve body can be run full auto as is, you can get the full manual option by adding their control module, the downside is brake actuation only in first.
The D3 brake valve body can run full auto or full manual with control module, can also actuate in 1-3 gears but requires you to actuate the brake to get reverse.
I believe it is AUTO first to run TB function. I will have to confirm once I wire it up.
They are straight. They are going to tie to the suspension to pick up the load there. Just not sure how yet.Are the rear bars straight? I can’t tell in the pic. They were in my cage kit and there was no way I was getting them to the frame behind the wheels.
