I need a judgment call: after removal, it does sound weird bouncing it on the floor. What do the pro wrenches think about this?
Converter side:
Crank side
Converter side:
Crank side
Looks like a crack to me is it?I need a judgment call: after removal, it does sound weird bouncing it on the floor. What do the pro wrenches think about this?
Converter side: View attachment 80528
Crank side View attachment 80530
Normally, I'm not sure it's a problem but I've seen a couple so sludged up that I can certainly see that it's a possibility.Did the Series 2 engines have an issue with pumping the sump dry during sustained high RPM's?
Yep there's your problem what's your solution?
Are they available and how much would it be for a crank and bearing kit for that motor?Yep there's your problem what's your solution?
