Not far off... I found what won't work, let's leave it for tomorrow......or is this another case of the oil change episode from the Red Green Show?
You got to drive it!FAIL
Took it out for a drive over to a friend's house. Exhaust thumps somewhere in the back, it fell and is sagging at the front, the donut on the y-pipe is leaking, there's some noise that I can't tell if it's engine or exhaust leak, the check engine light is on , and it's loud.
On the good side, it drives much better with the new gears.🙁
FAIL
Yea and all that pipe welding practice is so you get it right when you plum in the twins!wars aren't won by single victories, but from lots of small battles. consider today's a win, by driving it up the road!
you're probably just looking at an exhaust leak, as you didn't mention any other noise when you had it running in the garage, and CEL is probably indicating a lean exhaust due to the leaks. keep plugging away, you'll get all the little bugs exterminated in no time!![]()
