sbcCuttY said:I just wanted to get some info on the optima batteries.. I have a cutlass with achevy 350.. it is a street car..I just want to know what optima would be good..thanks yo
kiko said:I'm using an Optima Red Top; 800 Amp cold cranking; 50 Ah (Model: 34/78, #8004-003). It used to be mounted in the regular location under the hood, but now it's in the trunk.
Andry
bill said:Just FYI regarding Optima batteries. In order to charge them, they must be hooked to a good battery to "jump" it, otherwise, they wont take a charge from a charger. I know this because I have tried to trickle charge an Optima and it wouldnt work until I hooked it up to a good battery with 12.6v first.
Qdub24 said:bill said:Just FYI regarding Optima batteries. In order to charge them, they must be hooked to a good battery to "jump" it, otherwise, they wont take a charge from a charger. I know this because I have tried to trickle charge an Optima and it wouldnt work until I hooked it up to a good battery with 12.6v first.
I've done it on more than one occasion, so maybe you had something connected improperly.
