Passenger window wont work
Apr 9, 2022
2
Oregon
When I got my el Camino, both windows worked as they should, but out of nowhere, the passenger one stopped working. I tested it and there’s no power to switch or the window motor, anyone know what could be my issue?
78Delta88
528
306
SW Arizona
I'm assuming Driver Door works? Used to happen alot, even on the new cars. Make a jumper and connect to the switch, see if it works now. If switch and motor good, then most likely it's in the wire coming from the body and into the door. The wire breaks after repeated opening and closing of the door. Does the door speaker work and no static? Any recent work under or behind dash, such as HVAC or radio work? You will have to trace starting at the relay. Assuming driver door no issues... Then it's not the power relay or fuse, the issue will localize in pass door. If driver door also not working, then check power relay and circuit to and from relay. Always check grounds as well. Connectors get rusty and then circuits fail. At the dealership I made about a 20 foot jumper with alligator clip on one end and probe on other end. You would be amazed of what comes from factory not working, or fails first 6 months of new car. The cause was usually something preventable like connectors not completely connected, wires bent or pinched, insulation cut, scraped off, or missing.
2
Oregon
The window is the only electronics going to the door besides one wire for the door popper, I’ll check the door sill wires though, thanks.
