As does having EGR. Which then allows more timing. And can also be disabled easily.Retarding the timing. This reduces NOx.
.......yetafter what I ate tonite I'm glad I do not pass emissions....![]()
Since your registration is outside Bernalillo County, you're exempt. The Governor signed up for stricter rules...but only for 2011 and newer vehicles. MVD says nothing about any upcoming changes to add other counties.New Mexico - Sandoval County
If you did, the cat might object.😾after what I ate tonite I'm glad I do not pass emissions....![]()
As long as the carb is tuned in close, you aren't running a lumpy cam or one with a crappy LSA, and you have a catalytic converter installed, a sniffer test shouldn't be a problem. If you have to have all equipment installed and functioning to pass, the LS swap starts to make more sense as putting all the correct old equipment back on the old engine will not only be hard to find and expensive, but will limit it's power. An appearance only check will fall somewhere in the middle.
I thank the Lord every day for no inspection BS here.
If the OP needs to pass emissions, he may be better off buying another G body that is bone stock and hasn't been butchered and hacked by POs.
