Pics of Sun Visor mounting points?
shoedoos
406
403
Can someone please post a pic of the mounting points for their sun visors? I recovered the headliner and didn't mark or redrill the three screw holes before re installing.....and you're correct, I don't really want to remove the headliner now that its in.....G body Malibu by the way.....
DJHull
255
232
Lansing, Mi
Not the best pics but hope they help. This is a 79 Cutlass.
shoedoos
406
403
thank you, those pics have me sorted....just needed an idea of which direction the triangular mount was pointing
12,175
9,789
Cut the middle hole out and line up the mounting position of the sunvisor base. then as Greg pointed out, use an awl or icepick to locate the holes. Sometimes you might even be able to feel them with your fingers.
20,397
I would head to the wrecking yard, cut out each corner on the headliner and then match the edges to the new headliner and mark off where the holes are....or take a take measure with you to measure off the location of the holes
shoedoos
406
403
all sorted now guys.......on to the next issue.....drooping sun visors....yep, before I attack them with all the usual tape, velcro and zip tie solutions......anybody got tips that specifically work on our platform?
Rktpwrd
Builder of Cool Shjt
4,177
23,945
Calgary, Alberta, Canada
Tighten the Phillips screws where the shafts go into the visors. Simple as that.
shoedoos
406
403
^ out of luck on that front......the visor still droops when I tighten that screw.....and yes, its at the point of stripping out and the thing still won't do as it is told....
O. D. Showtime
3,008
3,539
Regina Sask. Canada
Isn't there a plastic sleeve where the mount pin goes into the visor...perhaps those are worn out or missing?
