Pontiac battery hold down
liquidh8
Ok guys, for the life of my I can't remember what these look like or how they mount. Most of my gbodies over the years have had the metal battery tray with the rubber block and 13mms bolt. The wheel wells I have have a slot,I believe it is a plastic strap, but I would love some pictures.
Thanks guys.
Reactions: Texas82GP
Search up GM part number 22512299 - this is the part number I found for the battery hold down bracket..
Ok, I see Highway Stars has it, that is one I was looking at. The next question is, is where does the bolt hole go too? My aluminum radiator support doesn't seem to have a hole when that looks to bolt to
Bumping this back up. I have Pontiac sedan inner wheel wells, and I am trying to get a pitcure of an oem battery hold down. It bought one for a Buick but it doesn't fit. I'd hate to use a universal, they look like poop [emoji90] [emoji90] [emoji90]
Sent from my Z981 using Tapatalk
Drivers side battery?
No sir, passenger side. There is no metal battery tray like the Malibu's and Monte, it's plastic like the Buick, but different.
Maybe I'm missing something?
I had to rig something up with a universal hold down.
I was afraid of that Mike. I may buy an Optima hold down so it clean.
The hold down that came with my GP appears to hook into the wheel well, then loop over the top of the battery, and is then secured with a bolt at the core support end of the inner fender/battery tray. I found it in the trunk. Mine is split where the bolt secures it, likely from somebody he-manning the bolt down. I can get you a pic if that helps. No idea if the GP hold down is the same as the LeMans. What car did your inner fenders come from? I can look in my parts book for a picture and a part number. PM me so I'm sure to get your response. I'm not able to spend as much time on here as I once did so plenty of threads get past me nowadays.
A picture would be great. The wheel wells came from a Pontiac 4 door, believe it was a Bonneville?
I'll pm you.
