Possible problem with quick performance disc brake kit
Turbosbc
38
27
Kangasala, Finland
Ordered complete rear end kit from quick performance. I installed disc brake brackets and calibers and it looks like the offset spacers should be longer? Slider bushings come all the way out and mounting pin/bolt end goes in the rubber.
Hope you understand. It is hard to find right words...
Other than that parts seem great....
Sanguia1
13
U fix issue yet?? U order right set?? Maybe pumping up brakes would align it?
Turbosbc
38
27
Kangasala, Finland
It is aligned in that picture. I Dont know is it the right ki or not. I ordered whole rear end kit.
I made longer offset bushings so the mounting bracket moved in better position. (more to right in that picture)
Sanguia1
13
Looks like sliding spacer had to much room to move instead of leaning up against that bracket . Possible u mixed up left.. right caliper bracket? Possible u put bracket outside instead of inside??
airboatgreg
2,870
3,116
I didn't have that issue but still not happy with emergency brake. haven't messed with it lately
