Power chip
Kmmurray73
6
I recently purchased a power chip from Hypertech for my 1984 Oldsmobile Cutlass 3.8 V6 . It says the computer is located behind the kick plate but I can't find it or find any information about it.
Kmmurray73
6
Passenger side. Did you check that side? Chip will be inside a metal box behind the kick plate, at least for 8 cylinder cars.
Yes I checked, so did my mechanic , he said he checked under the hood and behind the glovebox as well. He was the one that recommended I try a forum post to get any further information.
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
That's the only location that I have found them. Unless it was removed prior to your ownership, but that would cause other problems as well.
pagrunt
9,167
15,346
Elderton, Pa
All '81 up US market gas cars had the on the passenger side lower kick panel regardless of engine.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Step 1. Return chip for full refund.
Step 2. Find new mechanic!!!
Reactions: 4 users
Ribbedroof
4,904
7,009
Wellston, OK
Canadian car without ECM?
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
Your best option is to look under the steering wheel for the diagnostic port. If it has a diagnostic port, it at least had an ECM at one time. If it did have one, it obviously doesn't now. The "check engine" light would remain on at all times if it was removed and the vehicle was not reconfigured to run without it. Get a refund for the chip if possible, or reconfigure the vehicle back to original specs. Personally, I'd go away from the chip.
High Roller
215
37
Cowtown USA, MN
It's inside the passenger front side kick panel. Take top panel off, and wala.. then you'll see the metal ECM box
