Vs. 2 spring steel tangs acting as nuts on nylon threads? I think you're, fine. Ron Popiel said it best- "Just set it, and forget it!"
I thought about something like that.....maybe that would be easier... 🤔
*factory design....
Got my brakes brakes done the other day. For some reason my battery was dead. Hooked up the charger and found out the brake lights were on. Checked a few things and found that the pedal arm wasn’t contacting the switch. Got POd and quit for the day. Is the switch adjustable?
Thanx for the tipIn case you want to use nuts to secure the switch in place I was searching for thin nuts to use on the switch and found finally that nuts they use for lamp shades fit.
Atron Hexagonal Locknuts - Zinc-Plated - 1/8-in IPS - 6 Per Set
Secure any 1/8 IPS threaded pipe with an Atron lock nut. Its coarse thread gives you a firm grip when using it for stability. The hex lock nut has a ...www.rona.ca
