Hi guys
So I’m changing my mind with what the plan for my Cutlass was. Currently planning to swap in a big block and get it actually paint over the winter (should have enough for a good paint job them. Car is currently in bare metal (bought it like that) was thinking about sanding the surface rust off myself and sending it to a local shop to get primed. I was thinking to go with an epoxy primer because I heard it will be able to stand up to the weather. Living just outside Chicago I get all kinds of weather fairly quickly. I want to be able to drive it this summer so leaving in bare metal is not an option and if I drive it to work it may end up sitting in the rain but it will be in the garage at night and during the winter. What problems could this cause for when I go to paint it and what should I be expecting to pay to have the car primed? The car is a hurst olds and is worth painting eventually. The problem is that my theory is once you paint a car and have expectations of it being perfect, it normally falls apart trying to make everything else perfect.
