Problem 200r4
1320chevy
Jun 23, 2023
51
39
74
Bought an "exotic build" 200r4 transmission for our G body (85 montecarlo). Unit has all the bells and whistles offered. Special pump, special clutches, all thrust washers replaced with rollers, many hard parts custom made from billet or heavily modified. Valve body is of this companies own design and is supposed to be based upon the best oem but with many "secret" modifications. Converter was supplied by the same company and is supposed to be around 3000 stall with no lockup feature. OK, the problem is that the unit has never worked properly but being patient, we kept sending it back in hopes that they would make it work. (unit has been in and out of the car over seven times and NEVER has worked right. SO, WHAT'S THE PROBLEM? Well, it has finally sunken in that the shop that created it, is in way over their heads and simply don't have the knowledge base to draw from to make it work. The main problem is, this is a race car. During competition, the driver makes a shift at lets say, 6500rpm. The transmission does not respond. It does not slip and the rpms do not flair but keep going up as if the next gear had never been selected. Then, at random, it will shift. This is unpredictable with regard to rpm but always happens. You simply cannot depend upon it for any kind of consistency.. Yes, fluid is full and is not ever burned. The shop contends that this is impossible and that we are just wrong. We took this unit out of service and replaced it with a th350 and the problem is gone. so, it's not us or the car. This unit has cost us over $4,000 and I'd really like to have it working.
Sorry to hear of your transmission woes. However, You neglected to name the shop.
That and new in the group, first post ever is that above...
Sarcastic After You GIF by Celebs Go Dating
Reactions: 78Delta88
Shop is Extreme Automatics in Ohio. Very nice people but they just cannot service what they built.
And, yes, I don't regularly post in forums because when I began racing, there were no forums and you figured out stuff for yourself. Been racing since 1967 and have worked on many high $ cars and teams. Retired (ha) now. and have built this car for my nephew. Everything I've done works and it really annoys me to have relied upon someone else and for them to never get the job done. So, as usual, it's up to me to gather as much info as I can and do this myself.
Full manual - so are you saying you move the shifter to the next gear and it doesn’t shift?
