pontiacgp said:David Williamson said:Thank you and matter of fact I have a very very bad leak in my power steering pump as soon as I put fluid in, in a matter of 5 minutes it will all be on the garage floor.
So i will take the belt off, I will also buy a whole new pump cause of the leak.
you ran the pump dry so that probably is the problem and if you removed the belt the noise should be gone. It does not take long to fry a power steering pump. I'd check the pump before I bought new gauges...
Should I just cut the belt off?
