This isnt hard, whats circled is the circuits in question, unfortunaltly there is alot of yellow wires at the ignition switch, my advice is to check for power ignition switch. the connector is looking directly at it, the one you want it location b4 /circuit #37. should have power on it at all times, I believe all yellow wires should have power to them all the time. if you dont have power there and your certain fuse 10 in fuse panal has power, you have a bad wire between engine fuse panel and ignition switch
