After a good bit of research and a brief study of Bill Torovato's Max Performance Oldsmobile V-8s book, I've decided to nix the Super Cutlass idea due to hilarious ramping of projected costs when it comes to building up the engine enough so that it doesn't ****ing explode when I put any amount of boost into it.
As such, instead of the ideal 450+ HP blower'd Rocket 350, I'm aiming for a much more reasonable 250-300ish HP naturally aspirated Rocket.
As is, the preliminary build plan is such:
1. Have the crank machined to accept Chevy rods with an offset grind for mild strokering
2. Install forged 4340 Chevy connecting rods, probably Eagle ESP H-Beams, with their wrist pin holes bored for .980 pins
3. Speed Pro flat top forged aluminum pistons to help offset the bigass combustion chambers in my 8 heads
4. Converting to hydraulic roller lifters
5. Whichever COMP roller lifter camshaft is ideal for my engine, which I have no idea of at this point
6. Roller rockers, naturally.
7. Oil restrictors maybe?
8. Having the heads decked to lower the combustion chamber CCs, hopefully down to 70 or so
9. Port match everything, polish the exhaust ports, blend the valve bowls, grind out the EGR bump in the heads, etc
10. Tuner Hooker Super Comp headers, ceramic coated for maximum shiny
11. Fancy paint job with Hirsch Automotive's Olds metallic blue engine paint
